transmission or air conditioning or neither of the above.
1995 HONDA ACCORD
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
LAURAELLEN
Was making a 300 mile drive. Car did fine until very near the end of the trip. The light indicating D4, which is the gear the car was in, began to flash, and the car began to act like it was running out of gas. We drove the car far enough to be able to get off of the highway, locked, and safe for the night. Called friend who came to pick us up. On the following morning we returned to the car. Checked all fluids. 1/4 quart low on oil - which has been changed on 5/14. Car started right up. About 30 min later, service engine light came on and stayed on. Completed trip to friends (additional 30 min), and parked it. NOW sitting out of state, with my 2 sons, and do not trust the car. Any idea of 'what' the problem is would be very helpful, so I can get it repaired on get home! Thank you in advance for any assistance. Almost forgot. Had air conditioning running, and it dripped so badly, it soaked the floorboard all the way to the back seat! Related to troubles?
Jun 19, 2014 at 12:16 PM
CARADIODOC
  • 34,306 POSTS
It's unlikely the two things are related. For the AC problem, look under the hood on the passenger side of the firewall for a 4" long rubber hose hanging down with a 90 degree bend in it. Squeeze the end of it to open it up. That may dislodge the debris stuck in there blocking it. That is the drain for the moisture that condenses on the evaporator in the dash. When the drain is blocked, water builds up in the drain pan until it overflows onto the floor. If nothing comes out of that hose, squeeze the metal ring to pull the hose off the spout, then poke a pencil into the spout to clear the obstruction.
Since the Check Engine light turned on, there's going to be a diagnostic fault code stored in the Engine Computer. Many auto parts stores will read those codes for you for free. That is the place to start, but remember that auto parts stores are in the business of selling parts, not repairs. If a part is referenced in a fault code, it is actually the cause of that code only about 50 percent of the time. There can also be wiring problems associated with that part. Also, many codes only refer to an unacceptable operating condition and don't refer to any particular circuit or system. It's up to the mechanic to diagnose the causes of those conditions.
Jun 19, 2014 at 9:42 PM
