Transmission oil replacement
2000 NISSAN PRESEA
110,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
EBIMESH
  • 6 POSTS
What is the oil to be used for transmission (automatic 4 AT)?
Feb 16, 2018 at 10:24 PM
STEVE W.
  • 15,113 POSTS
Everything I find shows you can use Dexron III or Ford Mercon ATF in it.
Feb 16, 2018 at 11:53 PM
EBIMESH
  • 6 POSTS
Thanks.
May 4, 2018 at 2:46 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 6, 2018 at 4:48 PM
BBOSA LUTALO DENNIS
  • 4 POSTS
Presea 1995 ,which type of ATF should I use?
Mar 24, 2023 at 10:14 AM
Presea is Nissan Matic D ATF. It is important to use the recommended oil to ensure optimal performance and longevity of the transmission.
Mar 24, 2023 at 10:25 AM
BBOSA LUTALO DENNIS
  • 4 POSTS
Thank you and how many litres should I use?
Mar 24, 2023 at 10:55 AM
BBOSA LUTALO DENNIS
  • 4 POSTS
How many litres of nissan magic d ATF is needed for Nisssan presea 95 R11,engine GA15De?
Mar 24, 2023 at 11:11 AM
The approximate capacity for a standard transmission is around 7.6 liters (8.0 US quarts) of ATF.
Mar 26, 2023 at 12:27 PM
