That's a tough question to answer because it's likely you drive different distances each day and I'm not sure how much is leaking.
Approximately how much leaks in a week's time? For example, a pint, only a couple of drips, or more? Also, do you travel approx the same number of miles per week?
As far as checking the fluid, the only hard part would be accessing the check plug on the transmission oil pan. If you are able to reach it, I attached the directions below for checking the level. The directions indicate a specific temp to check it. Allow it to warm up to operating temp and that should be fine.
Take a look through the directions and let me know if you have questions.
See pics below.
Note: The engine needs to be running and the transmission in Park. If the engine is off, you will lose most of the oil in the transmission when checking.
May 1, 2022 at 7:52 PM
