Transmission oil
2003 FORD F-250
134,000 MILES • 6.0L • V8 • TURBO • 4WD • AUTOMATIC
NOAHAMATO1
  • 5 POSTS
So I am going to replace my transmission oil, and on the dipstick cover it tells me to use Mercon SP. and i already bought Mercon V. So i read that i cannot use the Mercon V. i watched a YouTube video and he used Mercon V on his truck. I am in a pickle because i already drained my transmission fluid and mixed it with my other oils.
Jan 6, 2019 at 7:51 AM
Good morning,
What transmission do you have in the truck so I can get you the correct information.
This is the info for the fluid. you need to know what transmission you have to be sure.
Fluid Types
Transmission Fluid Type
Torqshift .................... Motorcraft MERCON SP
4R100 .................... MERCON V
MERCON ATF is being replaced by MERCON V ATF as a service fluid, per TSB 06-14-4.
Capacities
Transmission Fluid
Automatic - 4R100 (4-speed) .................... 17.7 qts (16.7L)
Automatic - Torque Shift (5-speed) .................... 17.5 qts (16.6 L)
NOTE: Includes remote filter element change.
Jan 6, 2019 at 8:02 AM
NOAHAMATO1
  • 5 POSTS
Hello Roy,
i have an automatic torque shift (5-speed) transmission. so i cannot change out my Mercon SP for the Mercon v?
thanks,
Noah
Jan 6, 2019 at 8:55 AM
No, you need to use the SP for your transmission.
that is required due to the heat build up.
Jan 6, 2019 at 9:01 AM
NOAHAMATO1
  • 5 POSTS
Okay. Thank you very much.
Noah
Jan 6, 2019 at 9:54 AM
You are welcome.
Always glad to help.
Jan 6, 2019 at 10:10 AM
