Transmission oil type
2003 JAGUAR S-TYPE
67,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AUSTINO
  • 220 POSTS
Good evening, I heard that the Pentosin AFT 1 automatic transmission oil be used in my Jaguar s type car. Is this true? Thank you
Feb 16, 2019 at 2:19 PM
If you look at the attached picture, it indicates the type of fluid required. However, there are other brands which can be used in place of this. Just make sure it is compatible. Often times, there are universal fluids which can be used. Look on the label to confirm it will work in place of the recommended fluid.
Let me know if I can help.
Feb 16, 2019 at 10:04 PM
AUSTINO
  • 220 POSTS
Thanks again.
Feb 17, 2019 at 4:42 AM
You are very welcome. Let us know if you have other questions or questions in the future.
Feb 17, 2019 at 4:40 PM
AUSTINO
  • 220 POSTS
Hello good evening, do you know where I can get the Shell M1375.4 transmission fluid to buy please? I cannot get it to buy where I am living? I just heard that the valvoline Maxlife fully synthetic transmission fluid (ATF) can be used in my car.Is that true? Thank you for you kind response.
Feb 17, 2019 at 5:58 PM
Hi and welcome back:
Not knowing where you are located, makes it difficult to confirm. However, it is very possible that the maxlife will work. What I suggest is to check on the bottle or online to confirm it can replace what the car calls for. Also, there is an 800 number for valvoline you could call. Look at picture 1. I googled customer assistance for valvoline and this number came up.
Let me know if this helps.
Feb 17, 2019 at 6:42 PM
AUSTINO
  • 220 POSTS
Okay I am living in the Caribbean island of Jamaica. Thank you
Feb 17, 2019 at 6:43 PM
Wow! I envy you. Here it is 33 degrees and raining. Ugh!!! I need a change. LOL
Take care and you're very welcome. Let me know if I can help in the future or if you have other questions related to the ATF.
Feb 17, 2019 at 7:26 PM
AUSTINO
  • 220 POSTS
Good evening, thank you Sir .I will let you know what's going on.
Feb 18, 2019 at 2:28 PM
Sounds good.
Take care, and good luck,
Feb 18, 2019 at 5:26 PM
