Good afternoon,
The dealer is the last place you go. Go find an independent transmission shop who will properly diagnose it and repair it rather than just charge you $200.00 and tell you it needs a transmission.
As far as the shifting, the TPS or throttle position sensor is what controls shift times. I would have that checked to be sure the proper voltage signal is being sent to the PCM.
Is the check engine light on? If it is, do you know the codes?
https://www.2carpros.com/articles/automatic-transmission-problems
The throttle body assembly consists of the throttle body, the throttle position (TP) sensors, and the throttle actuator motor. The throttle body functions similar to a similar to a conventional throttle body with the following exceptions:
- An electric motor opens and closes the throttle valve.
- The throttle blade is spring loaded in both directions and the default position is slightly open.
- There are two individual TP sensors within the throttle body assembly.
The TP sensors 1 and 2 are potentiometer type sensors each with 3 circuits:
- A 5-volt reference circuit
- A low reference circuit
- A signal circuit
The TP sensors are used to determine the throttle plate angle. The control module provides each TP sensor a 5-volt reference circuit and a low reference circuit. The TP sensors then provide the control module with signal voltage proportional to throttle plate movement. Both TP sensor signal voltages are low at closed throttle and increase as the throttle opens.
Nov 23, 2018 at 2:37 PM
