Transmission not shifting into drive
2002 NISSAN ALTIMA
130,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
DRUESTEPHENS444
My car broke down so to say on the highway and i got it towed home safely. But what happened is it stopped accelerating. I put it in park and it revved perfectly fine. Then i put it in to drive and it slowly moved forward without pressing on the gas pedal. Then i pressed on the gas pedal and it didnt accelerate at all. I tried the same thing in reverse and got the same result. I put it into neutral after that and it revved perfectly fine but after i tried it in drive and reverse again it did not accelerate at all. Whats wrong?
May 24, 2016 at 11:48 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first auto parts rent gauge but you may need an adapter for fuel pressure.
May 25, 2016 at 6:32 AM
