When you place it in gear and try to accelerate, do the engine RPMs increase and the vehicle not accelerate?
Did you change the fluid in the transmission when you replaced the solenoids? It sounds like it could be a line pressure issue or low fluid. However, I need clarification of what exactly is happening.
If you haven't already, I recommend having the can-bus scanned. CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve the codes regardless of the module storing them.
If you have already done this, let me know what codes were retrieved. If you haven't, here is a link showing how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Also, I attached the directions below specific to this vehicle for testing the transmission line pressure. Take a look through them and let me know if you are comfortable performing them.
See pics below.
Nov 12, 2022 at 9:04 PM
