Transmission not moving on drive and code P0776
2007 TOYOTA HIGHLANDER
254,343 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Good evening, the vehicle's Transmission is not responding or moving when place in drive position, I scanned the vehicle the only code found on its memory is P0776. I removed the sump to access the solenoid, I applied voltage to them, all of them were clicking, then I erased the code from its memory after the test drive it works fine, after parking the vehicle for some time the code appeared again with the same symptoms. What could be done?
Oct 15, 2021 at 12:19 PM
The code is specific to the pressure control solenoid B. Did you actually replace it or just check the ones in the vehicle? As far as applying voltage to them, that isn't always a good way to check. How much voltage was applied?
If you did replace the solenoid, take a look through the attachments. They provide the diagnostics specific to this code and vehicle. Let me know if you are comfortable performing the tests.
See pics below.
Oct 15, 2021 at 8:04 PM
BLESSING EWOBOR
  • 754 POSTS
The voltage applied to them was 12-volts. and how will I know the exact solenoid? any diagram please?
Oct 15, 2021 at 9:51 PM
The solenoid valve (SL 2) is mounted on the valve body. If you look at the attached pic below, I highlighted it for you.
Let me know if this helps.
Oct 16, 2021 at 6:15 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you sir.
Oct 16, 2021 at 10:44 PM
Happy to help. If you have a chance, let me know how things turn out for you.
Oct 16, 2021 at 11:41 PM
BLESSING EWOBOR
  • 754 POSTS
Okay sir.
Oct 17, 2021 at 1:04 AM
BLESSING EWOBOR
  • 754 POSTS
It is now working fine.
Oct 20, 2021 at 1:19 AM
Glad to hear that. Was it the solenoid valve (SL2)?
Oct 20, 2021 at 6:07 PM
BLESSING EWOBOR
  • 754 POSTS
I replaced the valve body.
Oct 21, 2021 at 2:34 AM
Thanks for the update. I'm glad to hear it's working for you.
Oct 21, 2021 at 5:45 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much so far.
Oct 24, 2021 at 5:12 PM
