Good morning, nice to hear from you.
Is this a new or used transmission?
Did you have the TCM programmed after installing?
https://www.2carpros.com/articles/automatic-transmission-problems
I attached a wiring diagram for you to view. Check the fuses in the diagram for power on both sides.
This sounds like a bad transmission.
The 500 is for the vehicle speed sensor.
The U code is a no communication issue with the TCM.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
1. REMOVE BATTERY
2. REMOVE AIR CLEANER ASSEMBLY
3. REMOVE SPEED SENSOR (NT SENSOR)
(a)Disconnect the speed sensor connector.
(b)Remove the bolt and speed sensor.
4. REMOVE SPEED SENSOR (NC SENSOR)
Dec 31, 2020 at 4:14 AM
