Transmission not going into forward gears?
2001 LINCOLN NAVIGATOR
230,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
VINCEMCCRARY69
Parked the vehicle and when i went back to go it would not go into drive. Drives perfectly in reverse. Prior to this it has never shown any signs of a problem. what could this possibly be?
Dec 30, 2022 at 3:01 PM
This can be the gear range sensor not working but we need to run the codes to see what comes up.
This guide can help:
Here is the gear range sensor so you can check it out or replace it. Also make sure the fluid is clean and full.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
You might have a first gear shift solenoid that is not working as well, check out the images (below). Please let us know what happens.
Dec 31, 2022 at 11:32 AM
