Transmission not shifting properly
1991 PLYMOUTH ACCLAIM
98,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GORDON3053
My transmission (in drive) does shift through the lower gears, but car jerks (usually) through each one and usually not ending in the final gear. I will then drive at about 35 MPH (or less) at 2,500 to 3,000 RPM's, never shifts again.
I will stop, turn off car, then start up again, basically, then the same thing.
Transmission fluid level is okay, not old and mechanic doesn't have OBD1 scanner.
While looking for a scanner, thought to ask you for help and any comments.
Thank you,
Nov 20, 2020 at 9:10 AM
Good afternoon,
You can see the codes if you turn the key to the on position and turn it off 3 times. The last time leave the key in the on position. It will flash out codes starting with 11 or 2 flashes slow with a pause in between.
Try this and see what codes you find.
https://www.2carpros.com/articles/automatic-transmission-problems
Nov 20, 2020 at 1:13 PM
GORDON3053
Hello Roy,
Thanking you again.
Not sure my first response e-mail went through; sending again.
Thank you very, very much for the quick response.
Sounds good, great to me.
Nov 20, 2020 at 2:58 PM
You are welcome.
Keep us updated.
Let us know if you have any other questions.
Nov 20, 2020 at 3:02 PM
