Something is causing the transmission to go into what is called limp mode. Basically, the term is exactly what it sounds like. It is used to prevent additional damage to the transmission, but it allows you to "limp" to safety.
What you need to do is have the can-bus scanned to identify diagnostic trouble codes. That will point us in the right direction.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that shows how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if that is something you can do or have done. This is where we need to start.
Apr 21, 2024 at 6:22 PM
