Since there are no codes, this is where I would start. You could take things apart and confirm that shift solenoids, valves, are working, there are no obvious wiring issues, and the valve body is clean and nothing is sticking. However, that is a lot of work and very time-consuming, and may not indicate the issues.
Tell me, does it have an external tranny cooler? If you lift the drive wheels off the ground and place it in drive, does it do anything?
This is an electronically controlled transmission that electrically controls the line pressure, throttle pressure, lock-up pressure, and accumulator pressure, etc., through the solenoid valve. If I had to guess, that is what I feel has failed. However, it requires removal of the valve body to access and I'm not sure that is the cause. That's why I wanted to check the pressure.
I attached two pics below showing the location of the solenoid valve (SLT) location. I didn't highlight the DSL solenoid because it is responsible for reverse (working). However, that is why I asked about placing it in low gear. IT controls that as well. But, since we have reverse, that is why I feel it is a line pressure issue.
Let me know your thoughts.
See pics below.
Dec 24, 2021 at 4:59 PM
