Transmission (Allison 1000) goes into limp mode or nothing. I thoroughly cleaned the valve body, load tested the internal harness and solenoids, checked OHMS, replaced the high-pressure shift valve, no burnt fluid. Codes indicate valve C, D, E, not working. I have been trying to load-test the harness and can't find a wire diagram that matches the harness. At the connector to the transmission position A is a pink wire, (diagram says should be dark green) at the TCM Red connector I have Position 1 pink as well, but my wire diagram from ATSG says it should be blue? Transmission and wires have never been touched by 1 owner. I will attach the diagram I am working from.
Apr 21, 2023 at 4:59 AM
