The transmission is going into limp mode but the TCM is not logging any codes. Anytime I do the key on key off to extract fault codes all that ever comes up is 55 (end of codes). This has been happening for years but only occasionally and has always been remedied by shifting to park and restarting the engine. Now it is happening frequently and is not always cured by restarting. The transmission oil level and condition are fine. When not acting up, the transmission shifts normally.
The service literature provided by IMPALASS in an old thread contained some information that makes me question the transmission control relay as it is possible for it to be faulty yet not log a code. Thread found here: https://www.2carpros.com/questions/dodge-intrepid-1993-dodge-intrepid-transmission-drops-into-limp-in-mode-on
See excerpt below:
*On 1993-1995 my vehicles, relay outputs only checked for one second after start up. Consequently, if relay output is lost after that period, the transmission will go into limp-in mode with no DTC's.*** Beginning with 1996 my vehicles, relay output is always sensed, therefore anytime the switched battery drops below three volts, the transmission goes into limp-in mode and sets the code.
Does anyone have access to the same literature and would you be willing to email it to me? The diagrams above are of poor quality and I cannot expand for better viewing.
Any help would be greatly appreciated.
Thanks in advance,
Glen
See excerpt below:
Thanks in advance,
Glen
Dec 13, 2017 at 12:59 PM
