Limp mode
2012 HYUNDAI VELOSTER
95,085 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RONALD MORRISON2
When I put it into gear and pushed the gas pedal FI reach over 1500 rpm, so it bogs down. But if I keep it under that it will go up to five miles an hour then put it in second in a go up to ten miles an hour. After that it just wants to bog down when I pushed the gas pedal. The transmission light is on.
Nov 10, 2018 at 10:24 AM
It sounds like your car is in limp mode which can be caused by a dirty throttle body causing the throttle bore and computer to lose correlation. Start by disconnecting your battery and following this guide:
We should run the codes as well.
Nov 12, 2018 at 11:54 AM
RONALD MORRISON2
I cleaned the throttle body out before I did that my check engine light was on. So I reset the codes the codes were 7e8 and 7e9 and the rear speed sensor. I cleaned the throttle body and put it back on and started it up now it is still running the same way and I also checked the coils to number four is sparking but not firing.
Nov 19, 2018 at 11:29 AM
Those speed sensor codes can cause the issue. Here are the locations so you can replace them and see what happens.
Refer to DTC code "P2765, P2766" Input Shaft Speed Sensor
Check out the diagrams (below). Please let us know what you find.
Nov 19, 2018 at 11:34 AM
