It is located on the rear of the transmission.
Here are the directions for replacement. The remaining pics correlate with the directions.
______________________________________-
2002 Ford Focus Wagon ZTW L4-2.0L DOHC VIN 3
Output Shaft Speed (OSS) Sensor
Vehicle Powertrain Management Transmission Control Systems Sensors and Switches - Transmission and Drivetrain Sensors and Switches - A/T Transmission Speed Sensor Service and Repair Procedures Output Shaft Speed (OSS) Sensor
OUTPUT SHAFT SPEED (OSS) SENSOR
Removal
1. Raise and support the vehicle.
2. Place a drain pan beneath the output shaft speed (OSS) sensor.
pic 1
3. Remove the OSS sensor.
- Disconnect the electrical connector.
- Remove the bolt.
- Inspect the OSS bore.
pic 2
4. Inspect the O-ring seal for nicks or cuts; install a new O-ring if necessary.
Installation
pic 3
1. NOTE: Apply a light coat of petroleum jelly to the O-ring before installation.
Install the OSS sensor.
- Connect the electrical connector.
2. Lower vehicle.
pic 4
3. Check the transmission fluid level and add automatic transmission fluid as necessary.
4. Start the engine and move the trans-axle range selector lever through all gear positions.
Let me know if this helps.
Sep 19, 2020 at 1:35 PM
(Merged)
