Transmission issues
2006 CHEVROLET COBALT
128,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KINGJD123
  • 104 POSTS
I have the car listed above, and it has no reverse, and the transmission will not shift into neutral. When i shift into neutral it drives forward. When i drive it i don't feel it slipping or anything weird. No engine light on.
Jun 13, 2022 at 7:54 PM
This could be a couple of things. So, we need to start with checking the fluid level and condition to find out if there are any issues with this.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Also, we could have multiple issues, so we also need to adjust the shift cable just to make sure this is not the issue.
Please run through these two things and let's see what happens. I attached the process from the manual below on how to do this.
Let me know if you have questions. Thanks
Jun 14, 2022 at 8:40 AM
KINGJD123
  • 104 POSTS
Did both and changed transmission filter.
Jun 15, 2022 at 11:03 AM
If the linkage and fluid is fine and we have no reverse and only drive, then we most likely have a stuck valve in the valve body.
I am attaching the process below but if it were me, I would remove it and check how each of the valves move in each bore.
Those that are sticking, use emery cloth to clean them up so they slide easily.
Jun 15, 2022 at 6:44 PM
