Transmission not shifting properly
1984 MERCEDES BENZ 300D
249,000 MILES • 5 CYL • 2WD • AUTOMATIC
JALSP
  • 6 POSTS
I am having an issue with the transmission not shifting correctly. The transmission will shift into 2nd gear at 20 mph, 3rd gear will shift at 40 mph and no sooner, and it will not shift into 4th gear until I hit 75 mph. If I let up on the throttle down to 65 mph it will shift back down to 3rd gear. It will not shitf back into 4th until I go back up to 75 mph. I have checked all vacuum and put a new modulator valve on the transmission. This did not help. Same result. The transmission always starts off in 1st gear. I have read they should start in 2nd gear but this one does not. Transmission is a 722-315
Jul 11, 2020 at 10:39 AM
Good afternoon,
Is the 4 matic transmission? It was an option in that year.
https://www.2carpros.com/articles/automatic-transmission-problems
I would start by changing the fluid and filter. It sounds like a valve body issue where the valves are not moving smoothly.
Make sure you use the correct fluid as it makes a huge difference in how it shifts.
I attached a picture of the valve body for you as well.
BB00.40-P-0236-12A Automatic Transmission Fluids (ATF, Sheet 236.12)
Type
Aral Getriebeoel .................... ATF M12
Fuchs .................... Titan ATF 3353
Mobil .................... ATF 3353
Shell .................... ATF 3353
MB 236.12 ATF 3353 .................... A001 989 45 03
Jul 11, 2020 at 11:08 AM
JALSP
  • 6 POSTS
I have changed the transmission fluid and this did not help. Not sure on the type of transmission. The number on the transmission is 123 270 59 01 722 315 02 0520386. Not sure if this helps but it is a 4 speed and it does have an electrical connection on the same side as the modulator.
Jul 11, 2020 at 12:23 PM
Okay, check that main connector and make sure there is no fluid in the connector. If there is, the internal harness will have to be replaced.
Beyond that, it is most likely a valve body issue.
Jul 11, 2020 at 12:26 PM
JALSP
  • 6 POSTS
I did take the connector off of the kick down switch and I pulled the Bowden cable off as well and it did not change how it shifted. Still did not shift into 4th until 75 mph and 5,000 rpm's. And the other gears will not shift until 20 mph and 40 mph for 3rd gear and no sooner than that for each.
Jul 14, 2020 at 4:14 PM
Okay, this sounds like a valve body issue.
One thing,does the modulator valve have a vacuum hose on it? If it does, measure the vacuum. It need to be around 18-20 inches. That vacuum would come from a vacuum pump.
Jul 14, 2020 at 4:39 PM
JALSP
  • 6 POSTS
Yes, it has a line down to the modulator valve. It has at least 20 inches of vacuum. I have installed a new one but the same result.
Jul 14, 2020 at 6:49 PM
When you accelerate or raise the RPM, does the vacuum drop?
It has to have a signal of being under a load.
Jul 15, 2020 at 3:18 AM
JALSP
  • 6 POSTS
The VCV valve works correctly as you drive. I have had a vacuum gauge on while I drive. As I drive the vacuum goes down accordingly as I push the pedal. Transmission will not shift until it hits the speeds described in earlier post. And it will not shift into the next gear until it hits those speeds.
Jul 15, 2020 at 3:17 PM
Okay, good, then we are back to the valve body itself.
Jul 15, 2020 at 3:24 PM
JALSP
  • 6 POSTS
Do they rebuild the valve bodies? Would you know if a rebuild kit is available for this?
Jul 16, 2020 at 3:38 AM
A tech with knowledge can rebuild one. There is not much to them.
I do not have a parts manual to see if it is available separately.
Check around trnamission shops and see if anyone is familiar with this transmission.
Jul 16, 2020 at 3:54 AM
