Having two very concerning issues after a recent transmission fluid change/flush at 57,000 miles
-After a cold start, while the vehicle is in drive, attempting to accelerate from a stop, the vehicle doesn't move, but the rpm's climb into the almost 4,000 range.
-Again after a cold start, while the vehicle is in drive, attempting to accelerate from a stop, the car will move, but the rpm's climb into the 3,500-4,000 range before a shift is made.
I have noticed car does not do these things after each cold start. The shop that did the servicing rechecked the transmission and did not find anything wrong. Fluid level, pressures, filter, and solenoid were all fine with no signs of any leakage. They did do an adaptive re-learn in an attempt to help get the proper shift points back. That re-learn has not helped so far. I am wondering what else it could possibly be?
Feb 5, 2020 at 9:38 AM
