Transmission issues?
2006 MERCEDES BENZ ML500
110,000 MILES • V8 • 4WD • AUTOMATIC
ALAWISHES VANHUMPERDINK
I recently had an issue where one of my radiator hoses (I believe the upper radiator hose) popped off, causing a significant coolant leak. After this happened, my power steering went out, and my transmission stopped shifting properly.
I was able to resolve the power steering issue, and I’ve refilled the transmission fluid along with all other necessary fluids to their recommended levels, but my transmission issue is still persisting. It’s not shifting as it should.
Could the coolant loss have affected the transmission in some way? What steps should I take to diagnose and fix this issue?
Thanks in advance for your help!
Feb 17, 2025 at 4:03 PM
I would run the codes to see if any are present. Also, do you have transmission inside the coolant? If so, this will be the problem, please go over this guide to see what I am talking about:
https://www.2carpros.com/articles/transmission-fluid-in-radiator-coolant-reservoir
This guide can help gather the codes:
Please go over these guides and get back to us.
Feb 18, 2025 at 5:30 PM
