Hi Ken, I went out to my car, and I started it up open the hood, unplugged the MAF electrical connection and the car didn't turn off and then when I plugged it back in it the engine light came on, the code p-0097, p-0102. From those codes I think it suggests that I need to get installed a new MAF sensor. I got two other codes one was 60300 and the other one was negative 12,000,2 times for last code. The first two like I said suggest an MAF replacement for the other codes I do not have an idea. I did try cleaning the sensor I had no other luck. I was wondering if there was a way to reset the MAF to see if it is working or if I should just go ahead and get a replacement sensor, I'm still getting bad gas mileage.
Sep 3, 2022 at 2:29 PM
