Transmission issue, vehicle shudders at low speeds?
2014 SUBARU OUTBACK
155,000 MILES • 4 CYL • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
On low speeds, such as on my driveway, if going up it feels like it shudders and the gets a better but i feel something right at higher speeds but still drives okay. Battery was drained, out a new one, only code i see is this.
Also had these engine codes before i replaced the battery, changed the battery and deleted them and they went away, but check engine light was never on and is not on now.
May 29, 2023 at 4:13 PM
The p1724 code and the is the one P0021 code is giving us a clue it could be the camshaft sensor or a problem in the VVT system. Here is what is said.
P1724: Subaru does not utilize this specific code.
P0021: This code is defined as "Camshaft Position 'A' - Timing Over-Advanced or System Performance (Bank 2)."
Here is the camshaft sensor location. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 5:41 PM
BHAMDOC1973
  • 2,008 POSTS
Can you tell me what oil viscosity goes in these? it was actually over filled and I don't know what was used before.
May 30, 2023 at 5:48 PM
Sure,
Automatic transmission fluid CVT SUBARU CVT OIL FOR LINEARTRONIC - K0425Y0710
Jun 1, 2023 at 2:43 PM
BHAMDOC1973
  • 2,008 POSTS
Sorry i meant for the engine.
Jun 1, 2023 at 3:03 PM
Please post your new question here, you must be logged in.
Jun 2, 2023 at 10:01 AM
