Jerky between 2nd to 3rd ir 4th gear, once u pass 45mph its great. Replaced the actuator under air-box cause that's the code i had, p07a3 now code is still pending. Could that be a fluid issue? I turned the actuator with a screwdriver 14 times and dis coke back quickly. Sprayed cleaner in there still same. I did not do anything with the actuator below.
Aug 11, 2023 at 10:35 AM
