how do you reset the code to get the transmission out of the limp mode? it takes off in high gear.
Apr 23, 2013 at 6:10 PM
CERTIFIED EXPERT
it is in limp mode for a reason, re setting does nothing to fix the issue. you need someone to check it out, determine the failure, repair it and then re set the code with a scan tool
