Ran transmission dry briefly. still works but 5th gear is now singing... want to replace damaged internal parts. What do you believe is damaged in there? People speculate I burned the synchro- I am confident (mostly) to open the transmission and replace anything ruined but can't find where to buy such stuff. As I am here, I believe I have a parasitic battery drain. At the same time, the driver's side window switch went from one tap automatic roll down to a need to hold the button down to get it down. Thank you for being here, I heard good things about this site. Thank you, Matt
Jun 2, 2023 at 1:59 PM
