codes P0717 and P0718?
2009 HONDA CIVIC
190,000 MILES • 1.8L • 2WD • AUTOMATIC
JOPARIZOM
Which is a fault with the input/turbine speed sensor. Where is this sensor and how do I replace it?
May 18, 2020 at 11:20 AM
P0717 - Input shaft speed sensor failure. No signal
P0718 - Input shaft speed sensor failure. Intermittent signal.
I attached the testing for the p0717 code is you want to run through that to find the issue. I also attached the location and replacement information.
Let me know if you need more info and we can go from there. Thanks
May 18, 2020 at 3:36 PM
