Good morning,
If you have normal forward gears and no reverse gear, it is most likely a failure inside the transmission.
I would drain the fluid, add new fluid and inspect the fluid to be sure there is no metal in the fluid or chunks of material. A band and a clutch are used for reverse so it could be either one causing the issue.
Jan 19, 2022 at 3:46 AM
