Transmission fluid temperature sensor removal
2007 CHEVROLET EXPRESS
243,654 MILES • 4.8L • V8
MONEYSAM83
  • 32 POSTS
Hi guys, i would like some information on replacing the transmission fluid temperature sensor on the vehicle. i was told the valve body has to be taken down. is that true?
Sep 1, 2019 at 4:18 PM
I attached the location of the temperature sensor and it does appear to be behind the valve body. I attached the process on how to remove the valve body and the pressure switch so clearly you can ignore that part. It does not have a specific process for the sensor but that should be attached to the internal harness once you get the valve body down.
Thanks
Sep 2, 2019 at 5:53 PM
