My daughters 2013 sion tc transmission fluid has leak out caught it before she drove car like that . I’m going to change filter and pan gasket. Being some of fluid has leaked out how many quarts should I put in after changing filer and gasket?Does fluid stay in torque converter? I don’t want to put more than I need and blow new pan gasket and not to little to destroy transmission. I know procedure how to find level. Just need to know how many quarts I should add before starting procedure to attain correct transmission fluid level. I know you should drain the fluid then put that much back in but since a lot leaked out how should I proceed?
Thanks
Thanks
Aug 2, 2024 at 12:25 PM
