How to check the transmission fluid?
2005 SATURN ION
210,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
STEPHANIE SUE
2.2 ecotec
Battery in trunk
Not original motor/tans from vehicle
*Not sure year
*Not sure what it's out of
How to check?
Jul 13, 2021 at 6:59 PM
It is hard to know for sure if this process is going to be the same just because we are not sure the transmission is the same year but I doubt it will be much different.
Just in case, here is a guide that talks about servicing the unit in more general terms:
Below is the process from the manual on this specific vehicle. Please run through this process and let us know if you have other questions. Thanks
Jul 13, 2021 at 7:35 PM
SQM
  • 6,383 POSTS
Just about all of these GM vehicles uses DEXRON III transmission fluid for Automatic transmissions.
Fluid Capacity:
Bottom Pan Removal .................... 6.9 quarts (6.5 liters)
Complete Overhaul .................... 9.5 quarts (9.0 liters)
Dry .................... 12.9 quarts (12.2 liters)
Here is a guide you might find helpful:
I have also included the transmission fluid checking/replacement procedure.
Let me know if you have any questions.
Thank you.
Jul 13, 2021 at 7:42 PM
