The only way to flush all the fluid out of the torque converter and valve body is to perform a flush. Otherwise you will just need to drop the pan and then top off the fluid. Which is acceptable in most all cases including this vehicle.
Here is a guide that will help with this:
https://youtu.be/D7bgOjIRMMw
Below is the process from the manual on how to check the fluid after you service the unit.
Let us know if you have other questions. Thanks
Mar 28, 2021 at 5:31 PM
