Here are the specs for the transmission. Please keep in mind, the capacity is based on the entire transmission is empty including the torque converter.
2003 Mazda Truck Tribute 4WD V6-3.0L DOHC
Fluid Types and Capacities
Vehicle Maintenance Fluids Fluid - A/T Specifications Fluid Types and Capacities
FLUID TYPES AND CAPACITIES
Fluid Types
Automatic Transmission .................... MERCON ATF or equivalent
Capacities
Automatic Transmission Fluid 2.3/3.0 L .................... 9.5L (10 quarts)
Let me know if this helps and is what you needed.
Jan 8, 2020 at 8:54 PM
