Transmission Fluid And Power Steering Fluid
2007 HONDA ACCORD
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
HASEEB
  • 4 POSTS
I Bought my accord used from some guy and i am thinking of changing the fluid of power steering and transmission but i have heard it is not ok to change some and says it is..... can you please tell me should i change it or not? and if yes can i use other brand fluids ?
Jan 18, 2015 at 9:48 PM
MHPAUTOS
  • 31,937 POSTS
Will not be a problem to do a service and change the oil on both power steering and transmission, you can get into trouble doing power flushes on older transmissions, but just dropping the pan and filter should not be a problem, any brand of oil is ok, just make sure you use the correct grade for your cars systems.
Jan 19, 2015 at 12:31 AM
HASEEB
  • 4 POSTS
Thnk u so much!
Jan 19, 2015 at 12:35 AM
MHPAUTOS
  • 31,937 POSTS
ok, good luck
Jan 21, 2015 at 2:21 AM
