Transmission fluid after new transmission installed
1998 CHEVROLET BLAZER
4.3L • V6 • 4WD • AUTOMATIC
DEANNAMP
We had a brand new transmission put in our son's 98 Chevy Blazer. We have continually had problems. I'm beginning to think this may have been too big a job for the garage that did the repair. Since it was under warranty (bought from a Chevy dealership) they first said it was a bad transmission and got a replacement. Now every time we get it back from them, the transmission fluid leaks. They have repaired gaskets a couple of times. I assume if the work was done right, these leaks should not be happening. It is not just over-filled, the leak this time is probably size of a basketball and low on fluid now
Nov 15, 2015 at 7:15 AM
HMAC300
  • 48,601 POSTS
you have to find the leak first is it coming from front or by trans, it may be hose connection at radiator or a broken line or missing o ring have a trans guy look at this not a mechanic especially after it's been screwed up a couple of times.
Nov 15, 2015 at 8:42 AM
