Okay, the range switch controls that and maybe the issue.
I attached a picture and the procedure below for you.
1. Remove control shaft lever
a. Remove the nut and control cable.
b. Remove the nut, washer and control shaft lever.
2. Disconnect park/neutral position switch connector
3. Remove park/neutral position switch
a. Pry off the lock washer and remove the nut.
b. Remove the 2 bolts and park/neutral position switch.
4. Install park/neutral position switch
a. Install the park/neutral position switch with 2 bolts.
torque: 5.4 nm (55 kgf-cm, 48 inch lbs.)
b. Install a new lock plate and the nut.
torque: 6.9 nm (70 kgf-cm, 61 inch lbs.)
c. Bend claws on the lock plate to fix the nut.
d. Adjust the park/neutral position switch.
5. Connect park/neutral position switch connector
6. Install control shaft lever
a. Install the control shaft lever, washer and nut.
torque: 13 nm (130 kgf-cm, 9 ft. Lbs.)
b. Install the control cable and nut.
torque: 15 nm (150 kgf-cm, 11 ft. Lbs.)
Sep 13, 2019 at 3:51 AM
