What temperature of the transmission I need to check the transmission fluid level?
2007 TOYOTA COROLLA
251,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
YAZIDAN
  • 133 POSTS
I would like to know at what temperature of the transmission i need to check the transmission fluid level and the procedure also. Does the transmission ATF level needs to be checked when it's cold, hot or both?
Nov 7, 2024 at 9:23 AM
Here is how to check the transmission fluid level and the type of fluid used. The engine should be warm while checking the fluid.
Fluid Types
Fluid type: .................... Toyota Genuine ATF Type T-IV
Change Automatic Transmission Fluid Only As Necessary.
Generally, it is necessary to change automatic transmission fluid only if your vehicle is driven under one of the Special Operating Conditions listed under one of the Scheduled Maintenance Guide or Owner's Manual Supplement.
When changing the automatic transmission fluid, use only "Toyota Genuine ATF Type T-IV" (ATF JWS3309 or NWS6500) to aid in ensuring optimum transmission performance.
Notice: Using automatic transmission fluid other than "Toyota Genuine ATF Type T-IV" may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the automatic transmission of your vehicle.
Capacities
ATF CAPACITY
Drain And Refill: .................... Up to 3.0 L (3.2 qt., 2.6 Imp. qt.)
Dry Fill .................... 7.3 L (7.72 Qts.)
NOTE: Change automatic transmission fluid only as necessary.
Let us know if you need anything else.
Nov 7, 2024 at 6:33 PM
YAZIDAN
  • 133 POSTS
is there any temperature the transmission fluid level should be checked at? I read somewhere on the net it should be checked when fluid temperature should be between 160 and 175F, is it right? any info on all data?
Nov 7, 2024 at 6:39 PM
For a 2007 Toyota Corolla, the transmission fluid should be checked at a warm operating temperature, ideally around 104°F to 113°F (40°C to 45°C).
Nov 8, 2024 at 10:14 AM
YAZIDAN
  • 133 POSTS
confused now. The transmission dipstick has hot and cold marks, each one of them has min and max. So, do you mean by warm the cold mark? Also, when you say warm are you talking about the engine coolant temperature or the transmission temperature? This is what i read in the Haynes manual. please see picture.
Nov 8, 2024 at 10:47 AM
There is conflicting information about this, I would drive the car, or just start the engine and allow it to get to operating temperature and then check the fluid level.
Nov 9, 2024 at 10:47 AM
