Transmission replacement for police interceptor model
2000 FORD CROWN VICTORIA
239,000 MILES • 0.6L • 4 CYL • 4WD • AUTOMATIC
TBROWN0705
  • 6 POSTS
My transmission went out. I have a police interceptor with the police package ends in CA.. can you explain why no other transmission will fit or will it work just not as fast? please help. When I find one on line the VIN number says the transmission won’t work...
Jan 6, 2020 at 4:30 PM
Good evening,
They have different controls and that is why it will not work. If you want it to work, you would need a complete harness for the engine and transmission and have the ECM programmed to the police package. It would be costly.
I would just replace it with the correct transmission.
Jan 6, 2020 at 4:45 PM
TBROWN0705
  • 6 POSTS
Thank you for the response! I guess I’m looking for a transmission which seems so hard being it has 4 other police packages to
compare...
Jan 6, 2020 at 5:16 PM
Are there any numbers on the tag on the side of the transmission?
Also, check the driver's side of the transmission and let me know if there are 1 or 2 sped sensors on the transmission. This is not including the speed sensor on the tail shaft.
I attached the questions that need to answer for the correct transmission. There is only one option for non police. You need the code on the side of the transmission on the plate.
Jan 6, 2020 at 5:33 PM
TBROWN0705
  • 6 POSTS
Okay, I’ll have them look tomorrow and let you know. thanks
Jan 6, 2020 at 5:56 PM
TBROWN0705
  • 6 POSTS
I do know it’s a XW7P-CA.
Jan 6, 2020 at 5:57 PM
Okay, I attached 3 pages of the CA transmissions. they have both rebuilds and used.
Go to www.car-part.com
Jan 6, 2020 at 6:03 PM
TBROWN0705
  • 6 POSTS
Thank you so much!!!!!!
Jan 6, 2020 at 6:05 PM
You are welcome.
Always glad to help.
Jan 6, 2020 at 6:07 PM
TBROWN0705
  • 6 POSTS
Good morning, I found one that fit and a great price!! Thank you so much again and have a prosperous New Year!!!!!!
Jan 7, 2020 at 7:47 AM
You are welcome
Always glad to help
Jan 7, 2020 at 8:01 AM
