I have a Porsche Panamera 4S PDK 2010 (970).
The car will not go into R or D. When I clear the fault codes with an OBD scanner, the gears work again, but only for a short time.
When the fault code returns, the car seems to get stuck in about 3rd gear while driving.
I have already replaced the distance sensor (purchased from Fruugo) and the mechatronic unit, but the same fault codes keep appearing: P1731, P1732, and U0456.
Could you please help me diagnose this issue or advise what might be causing it?
Mar 16, 2026 at 3:00 PM
