Did you have any leaking issue before changing out the drain plug?
If not you might want to put back the original plug with a new crush washer.
Simply put the manufacturer for the plug that you have purchase from O'reillys is different than the manufacturer of the plug that was in your vehicle that you took out (given that was a factory plug).
Given they are made by 2 different companies, they will have different tooling and process of manufacturing. Which can create minor differences in the end product. Most of the time that is usually not an issue, but in some cases it can lead to problems. Both of the plug will look same visually but they can have minor differences, especially around the thread and flange area, which can create a leak. As I mentioned before, it does not mean that is why your car is leaking. But it could be a factor.
Hope this helps.
Thanks.
Aug 16, 2021 at 6:48 AM
