About a year ago I rebuilt the 5r55e transmission in my vehicle listed above. The overdrive drum and band where scarred and burnt. (Replaced the OD drum with new one.) After rebuild roughly 8 months later I noticed the direct drive was slipping every once in awhile. After a couple of weeks it got worse to where it would barely go forward in 1st from a start. However this only happens when the transmission is warm or hot, when cool or just starting for the day it doesn't slip.
I took it to a transmission shop and told them the problem and also that I rebuilt the transmission. They drove it around the block, and said the transmission needed to be rebuilt. They offered no other diagnostic, didn't drop the pan or anything.
My question is, could this be a clogged filter or bad solenoid? The fluid doesn't smell burnt, it makes no noise when slipping. I was hoping that instead of slipping the direct drive band was losing pressure and not applying enough to engage the band or gear. Is it worth dropping the pan and replacing the filter and valve body gasket and checking solenoids or should I just save up to replace the transmission?
Jun 8, 2020 at 5:45 AM
