solenoids put back and car won't go into gear
2007 TOYOTA COROLLA
130,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ERICHHOUL
  • 4 POSTS
I am replacing the shift and TCC solenoids, when I removed the internal I had the arm? And a three springs with plugs come out . The arm is stainless and notched. I'm looking for a diagram of the pieces inside so I can make sure there installed right . I got the solenoids put back and car won't go into gear. I also have a piece that fell out.
Mar 20, 2020 at 7:20 PM
ERICHHOUL
  • 4 POSTS
This is the part that fell out with the arm:
May 26, 2021 at 6:11 PM
You indicated "...removing the internal I had the arm." Can you explain? As far as the part, it looks like part of the detent spring/ball. That ball rides on a lever that is grooved. See picture 1 and let me know if that is where it came from. Also, picture 2 shows a different view.
Let me know. Also, where did the three springs come from? Do you have pictures of them?
ERICHHOUL
  • 4 POSTS
Thanks, I'll take pictures tomorrow the springs went up into the transmission with plugs, so I'll rip it back apart since it won't shift. So I re drained it and will pull off the housing tomorrow. I'm assuming that I didn't put the parts back in right.
When I pulled off the solenoid housing the springs and indents went everywhere. I tried to assume we're they went.
I appreciate your response and will get back on early morning.
You are very welcome. Let me know. I'll try my best to help.
ERICHHOUL
  • 4 POSTS
The arm that came out.
That looks like the manual valve / lever. See the attached pic and let me know if it helps.
