Changing engine so installing old damper assembly on new engine, what torque on these bolts? Please
Aug 8, 2022 at 7:35 AM
CERTIFIED EXPERT
As far as the torque is involved, I attached the directions below. The directions include the torque specs.
Take a look at them and let me know if that is what you need.
See pic below.
Image (Click to enlarge)
Aug 8, 2022 at 11:16 PM
BHAMDOC1973
MEMBER
This clutch looking damper is weird, how do i know which side the plate goes as it can go both ways. If this was a normal clutch i would have figured it out.
Aug 19, 2022 at 7:52 AM
BHAMDOC1973
MEMBER
Also, what is the part number for alignment tool?
Aug 19, 2022 at 8:10 AM
CERTIFIED EXPERT
The part number for the alignment tool is 09301-00210. I'm not sure I understand your other question. Are you using the original flywheel?
Aug 19, 2022 at 10:24 PM
BHAMDOC1973
MEMBER
Same flywheel, same clutch.
Aug 20, 2022 at 4:16 AM
CERTIFIED EXPERT
If I recall, it's the same on both sides. However, you want it the same as it was removed. Are there any bolt marks or indicators on it that would help make that determination?
