I changed the transmission motor mount and after it was dripping rather heavily antifreeze underneath in the center front area also after taking it to Aamco to have the fluid changed and a diagnostic ran on it which nether were done i was informed i needed a $6,400.00 transmission but my truck was shifting and driving fine however before taking it to them at times when i took my foot off the gas and coasted it would surge or but drive and shift just fine. But after 24 hours though this issue began happening a lot more and my rpm would go to a 3-4 then down again. It is low on gas as i didn't want to put any in and it brake down but by 48 hours after taking it to them it began to jerk not surge but still was shifting just fine so i did some research and found a number of things it can be so i began to do trial and error in hopes to find the issue cause by day three, it still shifts fine but it won't accelerate and the RPMs only goes barely over the 1 but not to the 2. so, i changed the following: the output transmission speed sensor, throttle body gasket, air filter, transmission fluid, not the filter though, the plugs, the oil, and the transmission mount and now it's leaking rather fast antifreeze from underneath somewhere but i can't tell and my Haynes manual is not very good at explaining most areas i need to know about. so, now my question is, do you think i may have damaged something somehow when i jacked up my transmission to change the mount, even though i only had the jack near the front and under the transmission? if so, can you tell me how to find and fix this issue and what are your thoughts on the acceleration issue considering it shifts into every gear just fine. I'm including a video showing the leak and how the engine sounds now.
Apr 16, 2022 at 7:02 PM
