If you lost a lot, two quarts may not have been enough. If it is low enough, it can cause lower pressure in the transmission and allow the clutch packs to chatter. That will cause them to eventually fail.
Did you check the level after you added the two quarts? If you haven't, start with that. When checking, the engine should be at operating temp, the engine running in park, and on a level surface. Take a look at pic 1 below. It explains things to look for.
The cooler needs replaced. There is quite a bit of pressure that is in the system. Most sealers won't work and if they do, it's not for long.
There are two different transmissions that could have been used. I will provide the directions for the removal and replacement of the cooler for both.
__________________________
2000 Chevy Truck K 1500 Truck 4WD V8-5.3L VIN T
Transmission Oil Cooler Replacement
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Transmission Cooler Service and Repair Procedures 4L80-E Automatic Transmission Transmission Oil Cooler Replacement
TRANSMISSION OIL COOLER REPLACEMENT
Removal Procedure
pic 2
1. Remove the two bolts securing the auxiliary oil cooler bracket to the radiator support.
2. Remove the auxiliary oil cooler from the radiator support.
Installation Procedure
Notice: Refer to Fastener Notice in Cations and Notices
pic 3
1. Install the two bolts securing the oil cooler to the radiator support.
Tighten the bolts to 12 Nm (9 ft. lbs.).
2. Ensure the guide pin bolt is positioned into the support hole.
_________________________________________
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Transmission Cooler Service and Repair Procedures 4L60-E Automatic Transmission Transmission Oil Cooler Replacement
Removal Procedure
pic 4
1. Refer to grille assembly. Refer to Grille Replacement (Chevy) or Grille Replacement (GMC) in Body and Frame.
2. Remove the two nuts securing the two cooler lines to the oil cooler.
3. For vehicles not equipped with the 4.3L- engine, remove the four bolts securing the auxiliary oil cooler to the radiator support.
pic 5
4. For vehicles equipped with the 4.3LL engine, remove the four bolts securing the auxiliary oil cooler to the radiator support.
Notice: Refer to Fastener Notice in Service Precautions.
pic 6
1. For vehicles not equipped with the 4.3L engine, install the four bolts securing the oil cooler to the radiator support.
Tighten the bolts to 10 Nm (89 inch lbs.).
pic 7
2. For vehicles equipped with the 4.3LL engine, install the four bolts securing the oil cooler to the radiator support.
3. Reinstall the grille assembly. Refer to Grille Replacement (Chevy) or Grille Replacement (GMC) in Body and Accessories.
Oct 21, 2020 at 7:10 PM
