Differential service instructions please?
2006 NISSAN FRONTIER
184,017 MILES • 4.0L • V6 • 4WD • AUTOMATIC
FRONTIER COOLER
replaced transmission from factory by dealer about two years ago. I work on the road, a lot of driving. I do need to service the rear differential can you show me how?
Jun 9, 2017 at 1:34 PM
You are not required to change the fluid but it asks you to check the fluid every 15,000 miles. Here is a guide that will help with checking the fluid:
https://www.2carpros.com/articles/differential-gear-oil-fluid-check
As long as the fluid is not low or burned then you are fine to leave it. However, if you want to change it, I would recommend changing it every 100,000 miles.
Here is a guide that will help with this:
https://www.2carpros.com/articles/differential-service
I attached the info below from the manual that will help with additional details on changing the fluid.
Please let us know if you have other questions. Thanks
Jun 21, 2021 at 5:41 PM
