Transmission control solenoid replacement
2006 FORD ESCAPE
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ADEADEROGBA
I need help on how to replace the transmission control solenoid.
Sep 4, 2018 at 7:36 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
That involves a few steps to remove the automatic transmission pan to gain access to the valve body. I have attached a few pictures explaining the disassembly process. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 5, 2018 at 2:42 AM
ADEADEROGBA
Thanks for the reply and the diagram they are very helpful. I was to change the Solenoid. However, the issue remain the same, when I start the vehicle, it take a long time for the transmission to engage and even after it engage it slip out again. Scanning gave me P0750, please what do you suggest?
Sep 10, 2018 at 11:41 AM
DANNY L
  • 5,648 POSTS
Hello again.
Were you able to change the shift solenoid? The code P0750 is for "Shift Solenoid A " I believe that was the same code from before. Hope this helps and feel free to ask any questions if needed.Thanks again for using 2CarPros.
Danny-
Sep 10, 2018 at 12:31 PM
ADEADEROGBA
Thanks Danny.
Yes, I was able to change it but the car still slip after few minute of driving.
Sep 10, 2018 at 4:44 PM
Good afternoon.
Just to add to Danny's help, did you replace the filter when the pan was down?
The 750 is a shift solenoid but will not cause it to come out of gear. That is a pressure issue possibly with the front pump.
Sep 14, 2018 at 11:02 AM
