Transmission control module, instrument cluster
1997 PLYMOUTH GRAND VOYAGER
180,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
TANNER CHARLES
Making whining sounds when shifting into drive or reverse occasionally does hard shifts going uphill. speedometer and everything on the dash is not working except the ABS light is on.
May 13, 2019 at 10:53 PM
It sounds like you may have two problems. let's start with the speedometer problem which will make the car shift funny. Please run the codes to see if a VSS is out. Here is a guide to help:
May 15, 2019 at 10:21 AM
