This car listed above has an ISS code 717 even after replacing the ISS. I suspect TCM, wiring or connector problems. Although there maybe something wrong with the shift solenoids or Valve Body, I am going to test and replace the connectors first. The problem is that I could not find a new 49-way TCM connector (I suspect the current one isn't right- somehow, it may have been installed from an incompatible car (but cannot be for sue). I have the 20-way connector and the TCM itself and the wiring harness. I got several connectors from other G6 cars but the Engine harness that has the 49-way TCM connector is unique to the G6 GTP 3.9 2006. I could not find this car anywhere (not the MALIBU 3.9 2006 either). So, I plan to rewire a TCM connector I got from a 2010 IMPALA (which happen to use the same TCM but not the same engine harness and the needed connector).
Q: is this wise? can it be done without damaging the connector?
if not, any advice as to how to proceed?
Jun 12, 2021 at 5:31 AM
